Re: 584 ihc hard shifting into reverse
Posted by JimB2 on April 09, 2012 at 18:55:52 from (174.115.9.174):
In Reply to: Re: 584 ihc hard shifting into reverse posted by merle england on April 09, 2012 at 18:38:43:
Hi Merle, you are welcome.
That was an easy fix but I did learn something about the 84 and above series with the electric T/A shift switch from Bernard le Mechano and that is there is a different START/Neutral switch on the clutch that also switches T/A into Lo when the clutch is depressed so that it makes gear changes easier.
JimB
