Re: 19149 Cub Govenor
Posted by WOD288 on April 12, 2012 at 09:05:44 from (65.241.18.25):
In Reply to: Re: 19149 Cub Govenor posted by screwstick on April 12, 2012 at 07:58:41:
Thanks, I will take a look at this. Concerning the jam nut/bumper spring, I screwed the jam nut/bolt all the way in and the idle had no response/change. I took it all the way out and all the way in and it made no diff. If I take it all the way out, does the spring come out with the bolt? I have have to check that bumper spring I guess to make sure it's not broken.
Thanks
