Re: 12 volt to 6 using solnoid
Posted by horsepoor on April 13, 2012 at 14:26:36 from (208.124.125.137):
In Reply to: 12 volt to 6 using solnoid posted by Zachary Hoyt on April 13, 2012 at 13:59:42:
merle t said: (quoted from post at 21:59:42 04/13/12) I wired my farmall model a using the wiring diagram.
alternator to amp and amp to starter side thru solnoid also jumper to switch will start fine but does not shut off even when I pull the ground cable.
have been going thru ballast restors also help
My drawing is bad, I know. This is how I did my Farmall 240 I used one Radio Shack switching diode 1N914-1N4148. They come in a 10 pack for a couple bucks. Used an indicator lamp assembly 272--0336 for an idiot light. I added the diode to the light since the light is a 100mA LED it only works for indication and does not have enough power draw, so the diode was needed as well. I left the ammeter in place, but if I have the dash apart again, I would switch to a volt meter. That would be more useful. Hope this information is useful.
-Horsepoor
third party image
This post was edited by horsepoor at 14:30:18 04/13/12.
