12 volt to 6 using solnoid
Posted by merle t on April 13, 2012 at 13:59:42 from (67.142.178.22):
I wired my farmall model a using the wiring diagram.
alternator to amp and amp to starter side thru solnoid also jumper to switch will start fine but does not shut off even when I pull the ground cable.
have been going thru ballast restors also help
