Re: 12 volt to 6 using solnoid
Posted by old on April 13, 2012 at 14:50:27 from (209.86.226.27):
In Reply to: 12 volt to 6 using solnoid posted by merle t on April 13, 2012 at 13:59:42:
What alternator did you use?? If it is a Delco 10si then you need a diode or resister or light bulb in the wire from the #1 terminal on the 2 wire plug. By the way NEVER unhook either one of the battery cables with the engine running because you can/will fry the alternator and can even kill your self if you touch the wrong thing at the right time
