Re: 560 farmall overheating
Posted by T_Bone on September 20, 2000 at 14:48:22 from (207.254.53.138):
In Reply to: 560 farmall overheating posted by dano-ill. on September 18, 2000 at 17:13:32:
I would look for bubbles in the water or black scum floating as that would be a headgasket or cracked somewhere. When you say radiator is clean did you take it out and have it roded at the rad shop? Bad T-stat? Ohhh the rare one. If the lower radiator hose has been changed does it have the spring inside the hose to keep from collapsing shutting off flow? This would only effect an engine running at high rpm as at low rpm it would cool just fine.
T_Bone
Post A Followup
: Re: Re: 560 farmall overheating
