Re: Hey Tractor Vet. Question about your fuel problem
Posted by The tractor vet on April 14, 2012 at 15:59:59 from (75.19.127.43):
In Reply to: Re: Hey Tractor Vet. Question about your fuel problem posted by gtski on April 14, 2012 at 14:13:34:
Yep , i still have my Holley box that went to the strip from back in 64 as i had three two bbls on my 61 ford . Lots of jets of all sizes gskts. power valves several base units float bowls Floates . Been stagger jetting since back then . Even have left over stuff out of the 4300 sires autolite that was run on some of the ford engines . Even played with running alkihol thru a holley . even played with turbos way before most ever thought about putting them on a car or gas tractor engine and yep made lots of spare parts.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
