Re: Early -vs- late H choke rods?
Posted by Nebraska Cowman on April 16, 2012 at 08:34:13 from (66.252.115.26):
In Reply to: Early -vs- late H choke rods? posted by Yooper Farmall on April 16, 2012 at 08:24:56:
You should be able to bend you rod so it does not bind to hard, or move the cables. Yes, it should be like in the drawing. You can weld a chunk in and lengthen your rod if you need too. Originally there was a spring deal to keep friction on the rod where it passes through the front tank bracket but they are always missing and most people don't even know what it looks like. (I do have one for a pattern)
