McCormick H loss of power
Posted by Al Carey on April 16, 2012 at 13:12:17 from (98.100.252.130):
The H starts good but after warming up it seems to not take the gas and causes flames to shoot out of exhaust. I done a compression test with:
dry 150 145 155 145
wet: 160 168 190 150 Could this be a burnt valve? Is it possible needing a ring job? It will back fire out the pipe when you try to give it gas. Some-times it goes into a stall and will not take the gas. I do see a small amount of what appears to be oil burning. Could it be a timing problem? I did set the magneto to where it is on number 1. Any ideas would be a big help.
