Re: McCormick H loss of power
Posted by jbp on April 16, 2012 at 18:18:42 from (64.57.160.254):
In Reply to: McCormick H loss of power posted by Al Carey on April 16, 2012 at 13:12:17:
With those compression figures you definately don't have a valve or ring problem. I would suspect your fuel mixture is too lean or ignition timing is late, or both causing the exhaust flames and loss of power. The first thing I would do is open the power jet in the bottom of the carb a half turn or so. The sediment bowl strainer and the small strainer where the gas line enters the carb may need a good cleaning too. Joe
