I would do a pressure test on the cylinder. I use an old spark plug. Braze a male air coupler fitting on it. You have to get cyl on exact top dead center comp stroke. You can use unregulated pressure but I use a two gauge leak down tester . After you do this on all cylinders and if you find a leak you will know which cyl it is. If no leak shows up but I am sure it will from your symptoms, then you can think about pressurizing cooling system. Dropping pan etc. I bet you have a high sleeve flange as you notice the gasket does not seal all the way around on those sleeves. It cuts across to conform with shape of comb chamber in the head. Common problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
