Im sure its not the head gasket..The first time I tore it apart wasnt sure if i reinstalled it upside down, then after i noticed it pushing water out i said well i will just get a new gasket, same problem so im thinking the worst now :( I can try pulling all the plugs tomorrow and hook the battery charger up and whirl it over and make sure the radiator is full and see if i can tell where exactly the water is coming from. Yes the water is getting into the oil. Before attempting to start i put fresh engine oil in, and that is one of the first things i checked after i noticed the water coming out the exhaust...the engine oil looked milkly and the first initial drain was water :( just dont know the easiest way to find my problem..i will start with removing the plugs...im wondering if a sleeve maybe did move on me after i knocked the pistons loose?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
