Re: Float Setting for a Zenith Carb on a Farmall 140 Needed.
Posted by Pete7 on April 18, 2012 at 05:44:26 from (72.65.27.19):
In Reply to: Float Setting for a Zenith Carb on a Farmall 140 Needed. posted by farmallhal on April 17, 2012 at 18:43:50:
Hi....I"d do what Teddy52food suggested. I always try to remember that the engine needs three things: spark, gas, compression to run or at least sputter. Gas is easy to check-squirt some in the cylinder and see if you get it to sputter. Having the compression "go away" in all 4 cylinders, to the point were it won"t even sputter is the most unlikely of the three. .
Pete
