Posted by farmallhal on April 17, 2012 at 18:43:50 from (76.4.181.200):
Trying to figure out why my 1966 Farmall 140 won't start. Have checked fuel flow to the carb and through carb, checked ignition and have good spark along with good voltage and a strong new battery. Tractor wasn't used last year but was ran a few times and is used as my belly mower tractor. It appears I don't have good suction to draw fuel into the cylinders. Removed a plug after numerous attempts to start and it was dry with no evidence of fuel. Tractor is stored inside a closed building and out of the weather. Checked all visible things for cracks and leaks but don't see any as an issue. Thought maybe the gas is not high enough in the carb might be a problem to investigate. Plan to remove carb tomorrow and take a look there next. Would like to know the float setting and is it measured with a gasket in place or without? Need to do a compression check but this has always been a really nice running and easy starting tractor until now. Thanks for your comments or suggestions, Hal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
