Re: 47 H
Posted by Brian on September 21, 2000 at 05:24:27 from (205.188.197.46):
In Reply to: 47 H posted by Dave Sholtis on September 20, 2000 at 16:57:59:
Dave,
Whatever you DO NOT pull it to try and free it. You will more than likely break some rather important parts. This is the procedure I followed to un-stick my F12, pull the head to be sure the valves are free(I had a valve job done in the meantime). Then I pulled the oil pan to get at the underside of the crank. I then filled each of the cylinders with penatrating oil, then took a block of wood small enough to just fit into the cylinders. NOTE: be sure to use as large a piece of wood as possible so you don't punch a hole in the top of the pistons!! Then every day before I went to work and when I got home I would smack each piston with the block of wood and a hammer then I would smack each crank arm journal with the block and hammer. And by the time the head was done with it's valve job I had the motor free!!
Good luck and take you time!! Brian
Post A Followup
: Re: Re: 47 H
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
