Re: Float Setting for a Zenith Carb on a Farmall 140 Needed.
Posted by blunted on April 18, 2012 at 19:53:27 from (208.126.58.204):
In Reply to: Float Setting for a Zenith Carb on a Farmall 140 Needed. posted by farmallhal on April 17, 2012 at 18:43:50:
i had the same thing happen to me on my A. but when i cleand the points, i got the roter turned 180 around. good luck
