Re: Cub starting problems
Posted by El Toro on April 19, 2012 at 09:04:23 from (108.3.225.57):
In Reply to: Cub starting problems posted by Kyrock on April 18, 2012 at 15:29:35:
Is your coil 12 volts? You need your points open to check for voltage at your coil and with the ignition switch in the "on position". I would try another condenser. Hal
