Cub starting problems
Posted by Kyrock on April 18, 2012 at 15:29:35 from (74.136.9.157):
I bought a 1964 cub, I had to put new points,condenser, and rotor button to get it to start, the carb, was a mess, I cleaned tank and fuel line and put a different carb that I knew was good. While doing the previous I was using a jumper box as my source of power..It is 12 volt system with an alternator and disturbor. I then installed a new 12 volt battery, tractor started and ran fine..turned off and started and ran and ran a few more times, everything seemed fine..Went to start later, it would not start, turns over fine, but I have no spark at the points. The amp gauage seems ot work ok, but now the needle is resting all the way over to the right,,ANY help will be appreciated,,,,Thanks
