Oil for repaired SH
Posted by VA Gasman on April 19, 2012 at 18:15:57 from (75.243.125.216):
I have had oil pan off and all pistons out.All washed and cleaned with solvent. Head is off and cleaned valve train and parts of oil and gunk. The inside of block has been washed and cleaned with solvents . Push rod holes all cleaned and washed. Can I flush out oil pump to make sure it is clean?
Should I go with a detergent oil oil or go back to straight sae 30.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
