Re: Oil for repaired SH
Posted by John G. Hasler on April 19, 2012 at 18:28:57 from (174.124.48.166):
In Reply to: Oil for repaired SH posted by VA Gasman on April 19, 2012 at 18:15:57:
> The inside of block has been washed and cleaned
> with solvents . Push rod holes all cleaned and
> washed.
Oil up the cylinder walls and all the bearing surfaces. Otherwise they may rust.
> Can I flush out oil pump to make sure it is
> clean?
Sure. Fill it up with assembly lube (not heavy grease!) when you are done. First, though, you may want to consider overhauling it. What was the oil pressure like before the teardown?
> Should I go with a detergent oil oil or go back
> to straight sae 30.
Use modern multi-weight detergent oil. The (bogus, IMHO) argument for non-detergent oil in old engines is that it might emulsify the crud but you've removed that.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
