H starting issues
Posted by metalmender on April 21, 2012 at 05:20:08 from (74.106.120.145):
Got a tough question I have an H that forever has started perfectly on the 6 volt system Last Sunday I tried to start it No spark, put in new points and condensor still no spark, put in a new coil still no spark so I checked with a multimeter, I get power out of the coil to the points, so I diconeected the wire coming from the switch to the coil and hooked a 6 volt battery charger directly to the coil and started right up, while running I reconnected the switch and disconnected the batery charger and it stayed running, after a half hour or so I shut it off and tried to restart it, wont start again hooked up the battery charger and fired right up any suggestions?? I know I have power coming from the switch but is there a specific voltage I should be looking for???
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
