Re: H starting issues
Posted by El Toro on April 21, 2012 at 06:51:22 from (108.3.225.57):
In Reply to: H starting issues posted by metalmender on April 21, 2012 at 05:20:08:
Check your voltage drop at the coil when cranking the engine. Since you're connecting the charger directly to the coil it is getting 6 volts. I would also check your battery's specific gravity using a hydrometer. Should have readings around 1.260. Your battery may be getting weak and when cranking the voltage drops to much for the ignition. Hal
PS: Since it stayed running when you reconnected
back to the switch your battery was probably being charged and had enough voltage for the ignition.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
