Re: Anyone ever did this with a Cub!
Posted by Haas on April 21, 2012 at 15:06:16 from (75.246.119.27):
In Reply to: Anyone ever did this with a Cub! posted by John M on April 21, 2012 at 08:38:18:
You probably should have replaced the input shaft bearing as well as the seal. Those input bearings are usually bad on the Cub if they have not been replaced before. Since the tractor jumps out of gear, that makes me think even more that the bearing is bad. You can split at the transmission, but getting the shaft back in the clutch is not so easy. If you do replace the bearing, make sure you get it in correctly. Easy to install backwards and then there is play back and forth in the shaft which causes problems with the shifting.
