Farmall SH loader issues
Posted by IAtractorKid on April 21, 2012 at 20:09:21 from (166.250.103.25):
third party image
third party image
third party image
Hey guys! Having some issues with my loader on my SH and
hoping you can help me out. Hopefully the pictures show up
clearly but i have an M&W live pump behind the distributor
with 3 spool valve in the loader. 1/2" pressure line from
pump to valve, 1/2" return from spool to loader upright
reservior, 1/2" line from bottom of loader upright reservior to
top of gutted belly pump and 3/4" line from bottom of belly
pump housing to supply side of pump.
Basically when i go to raise the loader, there is a long delay
before the loader moves at all. I know the pump is only 10 or
12 gpm but it seriously takes close to a minute of pulling the
lever back before the loader ever moves. Once it starts
moving it does pretty good unless i stop and then there is the
delay again. Also, when i go to lower the loader, i have to
very carefully as it seems to be dropping and not pressuring
down as it should. So...any ideas?????????
I was thinking i need to replace the 1/2" lines from valve to
reservior and reservior to belly pump with 3/4" to feed the
pump more volume. What do you think???
Sorry for the long post but thanks for the help!
