I wiped down the carb and clean off the outside to see if I could spot the leak. It's definately leaking from the gasket that sits between the upper and lower halves of the carb. The gas leaks even when the tractors is sitting without the engine running. The gas runs down and drips off the bottom of the carb. Does that still point to bad needle and seat or just a gasket?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
