Re: IH 184 Carb Problem
Posted by wayne in mn on April 21, 2012 at 19:24:04 from (24.179.181.201):
In Reply to: IH 184 Carb Problem posted by KDougM on April 21, 2012 at 18:50:41:
The needle & seat are not shutting off inside the carb.
The float may be damaged and getting too heavy or the needle/seat combo are leaking. Replace as needed.
Shut off the fuel flow at the tank each time you are finished using the tractor to help stop leaking when not running.
