Farmall Tractors Discussion Board
Re: Farmall A year
Posted by Eddie Petty, Courtland, Va. on January 10, 1999 at 02:32:14:
In Reply to: Farmall A year posted by Todd on January 09, 1999 at 23:47:21:
Todd,
Look real close at the area slightly above the magneto/distributor mounting flange, below the head/block parting line and aft of the fan bracket and you should see a rectangular,raised, flat casting lurking under all the accumulated crud. Use a wire brush and you will discover the engine's serial number (which in most cases was a match to the chassis serial number).
Post a Followup
: Re: Re: Farmall A year
