Re: Re: Re: Smoke At idle
Posted by 80 Grit on September 22, 2000 at 13:55:01 from (206.228.215.167):
In Reply to: Re: Re: Smoke At idle posted by FC on September 22, 2000 at 13:40:53:
I would not switch until I decided to do an overhaul. You could wake up the devil. If you want to remove the pan and valve cover and do a clean up that might be ok. Your risk is dislodging crude and covering the oil pick up and starving the oil pump and engine for oil. Smoking after extended idle is common to oil running down the valve stems due to worn valve guides and in some engines bad valve guide seals. I do not think your engine has valve guide seals but you could have that verified.
Post A Followup
: Re: Re: Re: Re: Smoke At idle
