Farmall 504 gas tractor
Posted by Dan in Arizona on April 29, 2012 at 07:39:41 from (98.177.231.44):
Looking how to contact Owen Aaland, he seems to be the expert and has help so many people with problems or if someone else might know how to replace the o-ring on the eccentric assy. shaft draft control (in the housing below seat) Farmall 504 tractor w/3 pt hitch. Eccentric shaft part # is 389273 R91 and o-ring is # 355967 R1 (this is where the hydraulic fluid leak is). It appears that I need to remove the cylinder and control valve assembly just to get at the shaft. I&T manual not to clear on that. Thanks for your help.
