No it should be 20 degrees or so above ambient, or less than block temp. If it is hot, it is either failing, or it needs a dropping (ballast) resistor. to change the applied voltage to ~6volts. That only if it is a 12v coil for use with an external resistor, or an actual 6 volt coil. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
