Posted by pete 23 on May 02, 2012 at 11:05:45 from (74.32.231.176):
In Reply to: Pete - Owen posted by The tractor vet on May 01, 2012 at 19:07:34:
Observe the sentry light. That little guy will tell you a lot. If it does not come on but tractor stops moving in one side when shifting from odd to even or vis versa, then put a pressure gauge in each clutch pack right test port right next to the pressure switches under floor board. If you got pressure but don't move in that side, you have internal clutch problem. Stripped out splines. Now if sentry light comes on, you have electrical problem. If it does not move at all, you might have power to sentry problems. Early tractors, most actually, got their power off left battery and that connector corroded away. Connect power to cab relay to get away from that. Pressure switch's are a big problem also. They leak internally, pressure balances on both sides of contacts, they close and you don't move in that range. Oh, man, many more things. Some place to start though.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
