560 Fuel injector pump
Posted by Gordon P on May 02, 2012 at 22:09:26 from (67.142.177.23):
I have a 560 diesel that had the fuel injector pump repaired. When I got it back I installed it per the instruction I have in a manual. When I try to pull start it, it only blows white smoke. I was told that the gear in the housing where the pump is installed may have jumped a tooth or two. Is there any way to insure that the gear is in the correct position? And is there perhaps a different reason it just blow white smoke and will not start?
