Re: My Cam Won't Fit After New Bearings Were Installed
Posted by Hugh on September 23, 2000 at 13:32:39 from (208.166.66.166):
In Reply to: My Cam Won't Fit After New Bearings Were Installed posted by cheg on September 22, 2000 at 15:57:41:
Sounds like you need to take the block and cam back to your machine shop and have them line bore your cam bearings. This is usually done when new bearings are pressed in. If your cam is indeed straight and true, then line boring to specs should solve your problem. I'd install new bearings before I'd touch the cam.
Post A Followup
: Re: Re: My Cam Won't Fit After New Bearings Were Installed
