If Mag too fast it fires BTDC
Posted by John T on May 03, 2012 at 09:03:11 from (216.249.82.117):
In Reply to: Please explain to me....... posted by oldtanker on May 03, 2012 at 08:46:38:
The problem with too fast cranking RPM (12 volts on 6 volt starter) is NOT running performance ITS THE STARTING THAT CAN BE PROBLEMATIC.
A Mag has ONLY TWO timings (Start and Run) unlike a distributor with variable mechanical RPM based or vacuum advance
1) The initial start timing is retarted by perhaps 15 to 25 degrees what is is once RPM reaches maybe 200 or so + (depends on Mag). The typical start timing is right at TDC BECAUSE IF IT FIRES TOO SOON BEFORE TDC WHEN SLOWLY CRANKING SHE KICKS BACK.....
2) The run time advance may be like 15 to 25 BTDC which in a mag ONLY kicks in when she reaches around 200 RPM + .....
THEREFORE if the starter spins it too fast shes might kick into the run time advance timing of 15 to 25 BTDC and thats baddddddddd when starting
Got it??????????
John T
