Re: If Mag too fast it fires BTDC
Posted by Nebraska Cowman on May 04, 2012 at 04:52:51 from (166.182.3.78):
In Reply to: If Mag too fast it fires BTDC posted by John T on May 03, 2012 at 09:03:11:
Exactly John. And engines start better slightly retarded. So depending how you have your mag timed you may have trouble starting if the impulse is not functioning. (ie 12 V spinning it too fast)
