McCormick starter removal
Posted by paul andersen on May 03, 2012 at 10:56:15 from (96.39.188.190):
Has any one had a problem removing the starter from an IH W-4? I think a Farmall H is about the same. My problem is that the back end of the starter motor bumps into the transmission housing before the starter can be turned enough to pull it out of the flywheel housing.
