Re: McCormick starter removal
Posted by John M on May 03, 2012 at 14:03:14 from (67.231.174.210):
In Reply to: McCormick starter removal posted by paul andersen on May 03, 2012 at 10:56:15:
Done it more than once! Take as many of the bolts out of the clutch cover as you can, loosen the one under the starter, and any others you cant get all the way out. With the bolts out of the starter, lift up with a small prybar on the starter side of the cover as far as you can. Starter will come out without having to buy a belt pulley gasket. (Or making one)
