Re: Farmall 1456 wiring question
Posted by MaverickM23 on May 04, 2012 at 04:44:05 from (216.169.165.102):
In Reply to: Re: Farmall 1456 wiring question posted by Jon Hagen on May 03, 2012 at 15:21:45:
So a jumper wire between the two outer most plugs on the voltage regulator plug. Then the repair plug is plugged into the original plug coming from the wiring harness. One of those wires goes to the BAT stud and the other one goes to one of the two prongs where the original wiring harness plug went into the alternator. I assume all the other wiring stays the same. Just want to be sure I have it right. Thanks
