Re: Farmall 1456 wiring question
Posted by Jon Hagen on May 04, 2012 at 07:36:07 from (69.26.23.96):
In Reply to: Re: Farmall 1456 wiring question posted by MaverickM23 on May 04, 2012 at 04:44:05:
Correct, #2 repair plug wire goes to the Bat stud along with the original bat wire.
#1 wire in the repair plug goes to one terminal in the original alt plug. The correct one will turn on the alt light when plugged in with the ign on and engine stopped+ repair plug connected to the alternator.
Jumper the outside terminals in the in dash regulator plug.
All other wiring remains stock.
