340 no Hydraulics
Posted by Art S. on May 04, 2012 at 11:56:19 from (75.219.131.170):
After sitting a while (not running), my “340” utility tractor was losing hydraulics. By moving leavers (back & forth) and after a few minutes it would come back. Thinking my pump was bad, purchased another used pump from (from a reputable dealer) also replaces the hydraulic filter, gasket and O-rings at the pump. Thinking I might have an air leak, I even replaced the short hose on the inlet line. Now I can’t get the hydraulics to work at all. I even put the old pump back on, with no luck. Any thought on what my problem is? Your help much appreciated.
