Thanks for the heads up Owen. I guess I should not absolutly trust an internet download wiring diagram , especially a 66 series diagram, and assume it is correct for a 56 series. The one I had handy(66 series diagram download), clearly shows the #3 wire connected to the battery at the starter.
This and your post had me really confused, so I headed out to the shed to stick a 12V test light in my 856 regulator socket to see if that #3 terminal is hot all the time or is switched. I found your diagram correct, #3 has switched power, so It would not discharge the battery through the 10SI field circuit when parked if all 4 regulator wires were connected together.
One question though,looking at your top diagram from IH. My jumper wire conversion only connects the F wire to the #4 gen light wire so the F wire can excite the field in the 10SI and make the factory charge light work.
Would not connecting all 4 regulator plug wires in effect connect #3 to#4 and disable the charge light, in effect wiring switched power around the gen light ??
Not trying to play know it all or start a fight, just trying to get the guy correct info to do his 10DN to 10SI conversion without cutting up a new wiring harness. Thanks for correcting me on #3 having switched power on a 56 series IH.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
