Re: Farmall 1456 wiring question
Posted by MaverickM23 on May 05, 2012 at 19:46:36 from (71.58.99.183):
In Reply to: Re: Farmall 1456 wiring question posted by Jon Hagen on May 05, 2012 at 10:24:00:
So I have been reading the posts and then took a look at the alternator on the tractor and it is an externally regulated one rather than an internal which I first thought. What they had on it was a Transpo D713L regulator on it. I guess what I need to do first is figure out if this alternator works or not with my new harnesses. As it was wired B+ to alternator top post and B- to ground with the regulator plugged into the alternator. The orange wire was connected to one of the wires from the original harness. Question is should this setup work without any other wiring modifications where the original regulator used to be. As I said before the original regulator was removed and wiring was just left hanging. The alternator looks newer and I want to check it before I get a new one. I have all the old harnesses removed and the one to the alternator was laying on the turbo and two wires were burnt through.
