Re: Cub stops when hot
Posted by gene bender on May 05, 2012 at 16:56:30 from (67.55.226.143):
In Reply to: Cub stops when hot posted by beargap on May 05, 2012 at 16:15:29:
When it stops check the spart then repair as n eeded as its probably your coil. If it runs for an hour it sure isnt gas.
