Cub stops when hot
Posted by beargap on May 05, 2012 at 16:15:29 from (50.29.229.183):
I have a 1950-vintage Farmall Cub with a 12v conversion. It has run well for the last 20 years that I have owned it, but this Spring it has a new problem. After about an hour of work, the engine dies like it is out of fuel (sputter sputter stop). Letting it sit for a while allows it to start again, but untill it has completely cooled down, it won"t run long. Fuel flows readily through the fuel line end connected to to carb. Points and plugs changed last summer, oil and filter this spring. Plenty of power in the battery, too. So what? Could this be a coil problem? Does the carb need rebuilding (last donw maybe 10-12 years ago)?
=Vic=
