Re: Cub stops when hot
Posted by jfavor on May 05, 2012 at 21:42:48 from (173.74.183.27):
In Reply to: Cub stops when hot posted by beargap on May 05, 2012 at 16:15:29:
The fuel inlet screen may be plugged. Remove the plug from the bottom of the carb and fuel should run out. Even if it does it wouldn't hurt to check it. Remove the fuel line and the brass fitting that it screws into. There's a fine screen behind it. It probably needs cleaning if it hasn't been done for awhile.
Another strange thing on my cub. The air inlet pipe was so cake with old dirt and grease it just barley had a small hole thru it.
