Farmall 706, starting not staying running
Posted by John V. on May 06, 2012 at 18:58:54 from (198.228.225.24):
706 gas, I replaced the plugs like you guys suggested and it helped alot, now it starts without starting fluid and will run, but only for about 5-10 seconds. It seems like the carb leaks gas. The rubber elbow at the bottom of the intake pipe is rotted through. So I wonder if leaking gas ate through. Any ideas as to what could be causing this? Everybody"s advice here has been great so far.
