Re: Farmall 706, starting not staying running
Posted by The tractor vet on May 06, 2012 at 19:26:48 from (75.19.127.43):
In Reply to: Farmall 706, starting not staying running posted by John V. on May 06, 2012 at 18:58:54:
Well lets start with fuel flow . Remove the fuel line at the carb and see if you have a full stream of fuel coming down the line . If not then the problem is at the tank . Now if someone put a inline filter between the tank and the carb it needs to go . All ya need is the screen in the sediment bowl. Now if there is good flow down the line then ya got a problem with the carb . Is the solenoid working do you have 12 volts going to it?? . If no 12 volts NO run . Then ya have to figure out why no Juice to it and ya have to start back tracking . If it is flooding then ya got a problem with the needle and seat . They ain't hard to work on
