The pimp is not the lift factor it is the size of cylinder. The belly pump if I remember right on that tractor puts out around 1200PSI so you need a bigger diameter cylinder to get as much lift as you would if the system was say a 2500psi system Either system will lift the same weight if you use the correct size cylinder for the PSI you have
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
