Re: Lift capacity of a belly pump?
Posted by david G on May 07, 2012 at 19:42:12 from (205.215.206.18):
In Reply to: Re: Lift capacity of a belly pump? posted by old on May 07, 2012 at 10:56:28:
I thought the belly pumps would put out about 700 PSI stock, or 900 PSI with the IH pressure kit. My live hydraulic puts out 1800 PSI.
