Another H Wide Front Question...
Posted by Crazy Red Power in SE-WI on May 07, 2012 at 17:33:23 from (68.114.237.14):
Before I do something dumb, I figured I had better ask. Can I offset the wide front by a notch? I currently have the left axle set to the fifth hole & the right axle is set to the sixth. Toe in was adjusted & is ok. The manual does say to adjust the axles so they are an equal distance apart. It dosen't say "Don't!". Am I going to wreck something?
Thanks,
Mike
